Factory Sunroof fully closing... and leaking
My 2005 2500 sunroof won't quite close all the way. It almost closes but leaves about a 1/4" gap where the back of the sunroof doesn't lift all the way up.
Of course it's rainy season and unless a push the back of the sunroof up manually it surprises me with cold water when I brake.
Not sure if there's an adjuster to raise the rear end of the sunroof or if I just need to take the thing apart.
If anyone could give advise on how to fix; or links on a factory service manual pointing on how this thing works I would very much appreciate it.
Thanks!
Thanks!
Sunroof not closing right
I'd like to give this a bump. I was searching for the same problem and not finding a solution. Is there a method for adjusting these sunroofs? I notice my sunroof works 100% proper except for closing. the back side ends up just below the roof metal leaving a significant gap. The water goes in and leaks out of the dvd player and run down the seatbelts (in extreme cases). I can push it up into place by hand, and it opens past that level to go into vent mode so its not obstructed.
Any suggestions?
Any suggestions?
