Need some ideas
The wire should be 18 or 16ga if I'm not mistaken. They may have pigtails which will save you from cutting your harness as long as they have both male/female ends.
Also, did you read my post above? Your gonna have a hard time expanding that stainless. You will likely have to heat it up so much that the rubberband will melt on the cheapo tools that are available to us. Stainless is really hard to expand even just a teeny bit much less than 1/2".
Well I guess I can use the adapters and weld them on, since I got rid of the cutout space really isn't an issue now, I'll just cut off the dump pipeand fit it to what I need.
I had a few ideas as to how to get a half inch out of it though by cutting reliefes in the pipe before trying to expand it.
