wanna add more lift
Old Oct 28, 2009 | 10:02 PM
mike1589's Avatar
mike1589
Default wanna add more lift
I just put a 5 inch lift on my 05 1500, but Im lookin to make it a little higher. What would be my best way of doin this (aside from a body lift). Right now I have 3 inch blocks in the back, so I could do either add a leafs or new springs, but Im not sure what to do for the front.
Old Oct 28, 2009 | 10:10 PM
kx250frider617's Avatar
kx250frider617
crank the torsions more.
Old Oct 28, 2009 | 10:13 PM
mike1589's Avatar
mike1589
they're already cranked. if i get new keys will it allow them to go higher?
Old Oct 28, 2009 | 10:50 PM
kx250frider617
then i don't know, i think adding keys and then cranking them will definetly put you higher but then it gets way out of the stock geometry of the suspension. I mean mine are cranked but adding keys then cranking those is like a double whamy on the ball joints. I think that might be a little too much. I'd say just a body lift. Tons of people add that to their suspension lift.
Old Oct 28, 2009 | 11:12 PM
mike1589's Avatar
mike1589
ya. not a bad idea. thanks for the info.
Old Oct 28, 2009 | 11:58 PM
cheapbeater's Avatar
cheapbeater
body lift or taller tires. what you got against bodylifts?
Old Oct 29, 2009 | 01:47 AM
xill's Avatar
xill
coil spacers might work, unless you already have those or your suspension lift won't allow spacers to be stacked on top
Old Oct 29, 2009 | 02:02 AM
PETE_YK's Avatar
PETE_YK
No coils under an 05 1500...
Dont crank the bars any more man, you'll kill your front end and in turn it will kill your wallet.
Old Oct 29, 2009 | 02:12 AM
xill's Avatar
xill
ah, i wasnt aware of that sorry
Old Oct 29, 2009 | 10:11 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The only thing I see left is a BL unless you want to get into a really expensive suspension kit.
