Buy a locker for my 2wd or sell the truck and buy a 4x4?
Old Nov 3, 2009 | 07:56 PM
connorgleason's Avatar
connorgleason
I got a couple quotes today. The Truetrac LSD was $507 for the part and $400 labor. The ARB selectable air locker was $975 for the part, $300 for the compressor, and $700 labor!! I think I'm changing my mind to the Truetrac as you guys have suggested. I liked the idea of the onboard compressor, but I could always buy that separate and install it myself. As for the $400 they were going to charge me....that seems high. How much do shops typically charge for an LSD install??
Old Nov 3, 2009 | 08:40 PM
Lifted4x4Astro's Avatar
Lifted4x4Astro
I would go with the TrueTrac. It is a very good posi. It is available at all times on dry roads, wet roads gravel, grass and sand. The TT is basically the same as the factory posi on the 10.5" and 11.5" rears in the 2500's and 3500's. $400 is a little steep for such an easy carrier to install. I would check around for prices but that may be the going rate in your area. I would suspect a shop will do it in 3-4 hours.
Just a side note. The ARB compressor is not rated for continuous operation and is a very low flow compressor. The lockers only need about 90 psi and just a little air. You would be wiser to put a better compressor (like a york) on your Cummins and then you can run air tools and air up tires easily.
Old Nov 3, 2009 | 10:21 PM
HammerZ71's Avatar
HammerZ71
Find another shop!!! The shop around here I send guys to do full GEAR INSTALLS for $300 an axle, and will throw a LSD in for no additional labor if you buy it from them, stating it only takes about 10 mins to install the LSD when doing ring and pinions...
Of course, if you are dead set on a compressor, just get one of these:
then screw the LSD, tires, locker ideas, etc. Just pull yourself out when you get stuck...LOL
