HID Help AGAIN
Old Nov 2, 2009 | 05:12 PM
damien1023's Avatar
damien1023
Default HID Help AGAIN
For those of you that have not seen the first thread looks here: https://dodgeforum.com/forum/3rd-gen...s-06-only.html
Ok so I got the caps today and installed ONE cap on the drivers side before the relay like I was told to do. The lights still work fine with the truck off but now they completely turn off instead of just flickering. Am I supposed to take the relay off my truck now since I have the 2 caps? Run one cap on each side like most of you are doing? Im getting so frustrated.... Thanks guys!
Old Nov 2, 2009 | 05:48 PM
damien1023's Avatar
damien1023
Nevermind guys, im throwing in the towel. Took the relay off and ran cap only and flash, flash, flash, off. im done with it lol
Old Nov 2, 2009 | 06:24 PM
4matty3's Avatar
4matty3
ya mine do the same thing. they eventually stop after ten minutes or so. im thinking off just cutting the wires and putting stock bulbs in
Old Nov 2, 2009 | 06:43 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Did you do the resistors on the bulbs. Ive never ran caps.
Old Nov 2, 2009 | 06:50 PM
damien1023's Avatar
damien1023
I'm sorry weed, I am using what they sent me which is I believe a resistor because when I had it installed the first time and switched it off it would take an additional 3 or so seconds for the bulbs to shut off (this was when they would work with the truck turned off.) I was mistaken when I posted earlier.
Old Nov 2, 2009 | 06:52 PM
damien1023's Avatar
damien1023
I had it like this... Factory plug -> Resistor -> Relay -> to ballasts -> to bulbs... Im at a loss honestly. Im just going to throw the silverstars back in until I can get this worked out. I dont know why I had flickering issues in the first place running a relay off the battery.
Old Nov 2, 2009 | 08:00 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats cool man. Take some pics of what they sent and lets see if we can help.
My kits goes like this.......battery->relay->ballast->resistors->bulbs
but my kit might be diff than yours. With the kit I bought from HID extra they sent something I thought was caps but to be honest, I havent even looked at it. I need to finish my kit but Ive got a few retros Im doing for others plus trying to finish my own projects so I cant see to get ahead and get that far.
Old Nov 2, 2009 | 09:05 PM
sharkhunter10's Avatar
sharkhunter10
my kit goes battery->Relay->Ballast->bulbs i have a diagram if you would like to see it.
Old Nov 2, 2009 | 10:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If these are what they sent to you, these are caps
Old Nov 2, 2009 | 11:28 PM
damien1023's Avatar
damien1023
Shark, if you could throw that up it would be cool... I'm 99.999999% sure its wired right though.
Weed, yeah thats what they sent out and it specifically says to install between ballast and OEM headlight harness
