Pulsating noise followed by the brake/abs light
Old Nov 5, 2009 | 02:18 PM
AkRam1500's Avatar
AkRam1500
Default Pulsating noise followed by the brake/abs light
I've noticed this happening a few times over the past year or so and I'd like to get it fixed.
While driving to work this morning I could feel a light thump in my truck along with my lights going slightly dim for maybe 1/4 of a second. It continually did this for about 10 minutes until my brake and abs lights came on, then it all stopped. I can turn my truck off then restart it and all is well again. Seems it only does this during cold weather or when we get a lot of rain. Brakes seem to work just fine but have not checked the abs by locking up the brakes. Does anyone know what might be causing this? I was thinking maybe there's a relay or valve that's sticking but I don't know that much about the brake systems on these things.
Old Nov 5, 2009 | 02:52 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
doubt its your brakes. sounds like an alternator or battery problem.
Old Nov 5, 2009 | 03:02 PM
dirtydog's Avatar
dirtydog
Moderate User
Is the "thump" what you refer to as a pulsating noise? I'm a bit confused here.
I agree with Feejay that you have a different problem, but that doesn't rule out the possibility of 2 problems occuring at once.
Old Nov 6, 2009 | 11:51 AM
AkRam1500's Avatar
AkRam1500
My battery and alternator are fine. The noise I am referring too is more of a "wump" and happens about every 4-5 seconds until the lights come on then it stops. It almost sounds like the abs valve/unit is cycling. If this were a battery or alternator problem, it would be occuring a lot more frequently and like I said before, this happens to me when it gets cold or there's lots of moisture in the air.
