Cutout question
Old Nov 5, 2009 | 07:11 PM
BigWillie's Avatar
BigWillie
Default Cutout question
This may be a dumb question, but it's a dumb question I don't know the answer to... If I install cutouts in front of the 02 sensor, how will that affect them?
Old Nov 5, 2009 | 07:17 PM
bwhite757's Avatar
bwhite757
You will throw a check engine light (CEL) and the truck will go into "Sensor Fault" mode and run at a preprogrammed setting which might cause the engine to run a little rough...
Old Nov 5, 2009 | 07:25 PM
BigWillie's Avatar
BigWillie
I've heard of "phantom" sensors that send off a code to the computer saying everything is running correctly no matter what, any negative side affects to this scenario?
Old Nov 5, 2009 | 08:56 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
nope. check the faq for the sparkplug non fouler trick for the O2 sensor. but why cutout before the O2?
Old Nov 5, 2009 | 10:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Is there even enough room to add the cutout before the cat? I know there isnt on mine.
Old Nov 5, 2009 | 11:24 PM
BigWillie's Avatar
BigWillie
My neighbor is a welder, and I've already conned him into helping me with the headers. We were looking at my options and he came up with that idea. Figured if he thought it would work why not look into it... The space issue he's planning on solving by chopping off a section before the Y-pipe and sliding the cat back then welding the cutout in the gap left in front of the cat. The two possible negatives were the sensors, which Y'all have solved and the issue of too little backpressure.
Old Nov 5, 2009 | 11:34 PM
BigWillie's Avatar
BigWillie
I couldn't find the thread could you post a link?
Old Nov 6, 2009 | 07:07 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Here is a link for you
http://www.thefastman.com/02Simms.asp
Old Nov 6, 2009 | 08:49 AM
xfeejayx's Avatar
xfeejayx
read truckin151's threads on his headers. you do NOT want to cutout before the cats. he couldn't stand it.
Old Nov 6, 2009 | 09:17 AM
truckin151's Avatar
truckin151
Read from post 46 on...
https://dodgeforum.com/forum/3rd-gen...eaders-on.html
