Need some help, code P2100
Old Nov 7, 2009 | 07:05 PM
otter1363's Avatar
otter1363
Default Need some help, code P2100
Is Throttle body actuator control motor circuit open. I put a new set of heads on today. Truck fired up fine. Was cycling on/off to warm up and open the t-stat. I used the peddle and it reved fine the first fire up. About the third cycle i threw this code. Wont rev now only idle. I dont hear the TB click like it usually does either. Disconnect & re-connected the TB plug several times. Wondering if the TB took a crap?? Any one throw this one before?
'05 Ram 1500, 4x4, 5.7L
Old Nov 8, 2009 | 02:05 PM
dodgenitto's Avatar
dodgenitto
P2100 Throttle Actuator Ctrl Motor Circ/Open
Old Nov 9, 2009 | 01:54 PM
02WhiteRam's Avatar
02WhiteRam
Check for any wires going to the throttle body that you may have pinched while installing the new heads.
