Retrofit Projector and LED Halo Pictures Finally!
Quick question, has anyone installed there own projector lights? If so, how in the hell do you remove the factory installed headlight unit? I was just poking around thinking about buying some of these and I could not see how they are removed. I know you have to take the whole assembly out to even change a bulb so I figure someone here must know how to remove them.
Edit... I think I figured it out, you have to remove the inner fender (splash) panels in order to access the upper most clip?
Use the search function to check up older posts that have this all covered.
