2002 4.7 fuel injecters
Old Nov 11, 2009 | 08:01 PM
EvlKenevl's Avatar
EvlKenevl
Default 2002 4.7 fuel injecters
I'm thinking I need to replace my fuel injecters. I hope someone here can point me in the right direction in doing this.
Old Nov 11, 2009 | 08:55 PM
02Steve1990's Avatar
02Steve1990
how many miles you got?
Old Nov 11, 2009 | 10:54 PM
AIR RAM's Avatar
AIR RAM
Why do you feel they need to be changed? Also, fight the erge to go larger. There is NO NEED for you to run a larger injector. Just go with the same factory size but look into a BALANCED set. A balanced set is worth 15RWHP over the factory injectors which have not been flowed matched.
SPEED SAFE, AIR RAM
Old Nov 12, 2009 | 08:06 AM
EvlKenevl's Avatar
EvlKenevl
SPEED SAFE, AIR RAM
my truck starts fine in the morning. But if I try to start it 7 or 8 mins after I last shut it off, it will have to turn over for 10seconds or so.
Fuelpump is 10months old, plugs are 4 months old and I replaced a busted ground strap(body to motor)
The truck has 240,000 kilometres on it aswell
