Lampout
Old Nov 11, 2009 | 10:10 PM
mrls2gto's Avatar
mrls2gto
Default Lampout
hey guys new to the dodge forum, but i have a lampout notice blinking on and off at random. non of my lights are out though so im stumped. any ideas will help thanks.
Old Nov 11, 2009 | 10:23 PM
chambers's Avatar
chambers
According to my owner's manual the lamp out light comes on if there is a defective bulb or wiring circuit detected in the headlamp system. So maybe start w/ replacing your bulbs if you haven't done that in awhile.
EDIT: After reading a bit more it looks like it could be any of your exterior lights like markers, headlights, turn signals, or brake lights. Have you checked your turn signals and brake lights?
Old Nov 14, 2009 | 05:46 PM
perfectlytuned's Avatar
perfectlytuned
Mine does the same thing on th freeway when i hit bumps, not often but i do notice it sometimes. Its normally a loose bulb or connection, its kinda a pain in the *** but id check all ur bulbs to make sure there all plugged in. I have found bulbs that literally were burned and had plastic melted over the connectors. when a bulb really goes out, the lamp out light will come on and stay on
