Changing transmission fluid
Old Nov 12, 2009 | 04:49 PM
esparr1's Avatar
esparr1
Default Changing transmission fluid
So I'm about to change the transmission fluid in my 2006 ram 1500. I've heard that amsoil is the best to use, but I wanted to get some input from everyone first
Old Nov 12, 2009 | 08:00 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Some use Amsoil, some use Mob1 but I use RP. Do you know why? Because it is the best you can use and buy.
Seriously though, youre going to get lots of diff answers and opinions on this
Old Nov 12, 2009 | 09:02 PM
MikeHTally's Avatar
MikeHTally
I used Valvoline ATF+4 -- $3/qt at Advance. Make sure you get the right flat filter (the spin-on is apparently the same between the 4x2 and 4x4, but the flat filter is different). Sounds like you've done this before, so you know it's a MESSY job, but easy enough.
Good luck and have fun :-)
Old Nov 14, 2009 | 12:14 AM
OlDirtyJohn's Avatar
OlDirtyJohn
just in case you have any questions regarding the oil change itself, check this out.
http://www.60ateight.com/DodgeRam/
its a great write up. should probably be placed in the faqs section as a DIY topic.
Old Nov 14, 2009 | 12:39 AM
Jonhyboi's Avatar
Jonhyboi
+1 on the RP. I never used RP yet but I heard it works wonders.. some of my friends that drive diesel trucks use it and it improved there gas mileage and there shifting was smoother.. but then again that's the diesel world.
Old Nov 14, 2009 | 04:44 PM
BEAR's Avatar
BEAR
I use RP in everything on my truck. I have heard some good things about Amsoil and would try it if I could get my hands on some.
Old Nov 14, 2009 | 05:17 PM
esparr1's Avatar
esparr1
Thank you guys. I have heard good things about Amsoil. Surprisingly RP is a new one to me. I'll have to check into it though
Old Nov 14, 2009 | 05:54 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
IMO, go buy all new bolts for your trans pan. A lot of guys snap the heads off when putting them back in. I replaced all mine with grade 5 bolts and didnt break any going back in.
Old Nov 14, 2009 | 09:50 PM
Dodgeboy77's Avatar
Dodgeboy77
+1 on the amsoil. my buddy's grand cherokee had a leak caused by a stupid garage and his wife drove it with practically no fluid. he filled it up (after they fixed the leak) and it is still good.
Old Nov 15, 2009 | 11:43 PM
esparr1's Avatar
esparr1
thanks for the heads up about the bolts
