Tuning with Diablosport
Here are my two points where the KNK came on. Both points were only for a second, is this ok on the ST KNK or do I need to add more fuel. I have the 93 tune installed as is with 93 gas in the tank. The run was at WOT. The only things I adjusted on the tune were the tranny shift points and the idle. Thanks
Even that tiny ST KNK I should still remove timing. I thought I read somewhere that the ST KNK was ok, but if you are saying to remove timing, I probably should. I just find it hard to believe that the "canned tune" would allow any KNK. I use good gas that is 93 with no ethenol. I will try the 91 tune and see what happens....thanks for the help. I really want to learn how to make the most of this thing!
from my understanding after reading a ton of stuff on the DSP forums, i guess its pretty common for the 93 tune to cause some KNK. there really isnt that much of a difference between the 93 and 91 anyways. so you might as well just run the 91.
