E Brake Light
Old Nov 17, 2009 | 10:05 PM
jif102's Avatar
jif102
Default E Brake Light
I have a 06 Ram 1500 slt with the hemi in it. Every now and then there will be a chime ding and then the e brake light will come on. It will stay on when the truck is moving. Sometimes after one restart it goes away. Sometimes it comes back. I have a code reader but I have not remembered to check for codes when it comes on. What could be causing this and what should I look for?
thanks.
Old Dec 5, 2009 | 04:40 PM
bigbluehemi's Avatar
bigbluehemi
I have the same problem, plus my ABS light comes on. When I restart the truck it may stay off for weeks, then eventually it comes on again.
I wonder if this is caused by the rear wheel sensor or if the rear brakes need adjustment? My brakes seem fine but something must be causing this.
Old Dec 5, 2009 | 05:36 PM
moosefire66's Avatar
moosefire66
I had that on my truck for a while, Occasionally when I would use the E-brake, it wouldnt come all the way back up. What I had to do is pull out the E-brake return handle, and while held out, I pulled up the E-brake peddle with my foot. It wasnt returning all the way, and causing my light to come on. Hope thats all that it is for you.
Old Dec 5, 2009 | 06:10 PM
mopar6spd's Avatar
mopar6spd
My parking brake light comes on whenever i spin the tires in my truck. No idea why.
