Power Wire questions.
Old Nov 19, 2009 | 12:57 PM
AWE Daniel's Avatar
AWE Daniel
Default Power Wire questions.
Ok so I went ahead and made a power wire using the 4.7ohm 1/2watt resistor, and put that in with the male/female connectors so I could swap it in and out. So im starting to wonder if i did this right or not, here is what I noticed.
When floor the pedal, it seems like either the power has moved up to higher rpms, or the truck is double downshifting because it takes longer to get moving. I haven't quite decided which one yet. Its almost like there is a little dead space and then it takes off. Also it sounds like the intake is sucking in alot more air, i can hear it quite clearly with the windows up. I also noticed cranking the truck with the wire on is way different, it fires real quick and i can see the tach jump up really quick before it settles down. I also hear alot of air coming through the intake when this happens.
As of right now i have the power wire off and its just fine, none of these things happen, and Im leaving it off for now. I was wondering if you guys noticed any of these things? I thought it wouldnt be much of a difference at all if any. Anyways I'll get a second opinion later this afternoon when my brother comes over. Thanks for your input as always you guys are really helpful with this stuff!!
Old Nov 19, 2009 | 09:35 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Are you sure all of those symptoms are there with the wire on and then not there when it is off? I mean, its not going to cause more air sucked in. Thats mechanical.
