Guy's where is the DIY for the Hella 500's??
Old Nov 22, 2009 | 05:59 PM
EJM05's Avatar
EJM05
Default Guy's where is the DIY for the Hella 500's??
Ok so I have been searching for 30min and I cant find the DIY for the Hella 500. Its not in the FAQ and I've tried typing all keywords in the search. FML. I know its on here somewhere because I've read it before. Can someone please help me. Thanks
Old Nov 22, 2009 | 06:13 PM
Jram47586's Avatar
Jram47586
This could be wrong thing to say on here but there is a couple on dodge talk.
http://www.*********.com/forums/showthread.php?t=156368
Jram47586's Avatar
Jram47586
I guess that it is a bad word on here...
Old Nov 22, 2009 | 06:19 PM
JOHNSN10's Avatar
JOHNSN10
do u really need a diy?
Old Nov 22, 2009 | 06:21 PM
EJM05's Avatar
EJM05
Is it hard. I want to buy a set. Is a direct plug and play?
Old Nov 22, 2009 | 06:25 PM
EJM05's Avatar
EJM05
Yea I erased the stars and put in dodge talk and then it worked. thats what im looking for. thank you.
Old Nov 22, 2009 | 06:38 PM
AsphaltCowboy's Avatar
AsphaltCowboy
does it just work with the hella's or can i use the set of PIAA 520 fogs that have been sitting in my garage for the past few years?
Old Nov 22, 2009 | 06:50 PM
Hoss356's Avatar
Hoss356
No, only the Hella's will work since they are specially designed to shine thru the dodge 1500 grill. That is of course as long as you have the normal louvers and not the honeycomb grill inserts. If you have the honeycomb inserts you will have to use KC daylighters.
Old Nov 22, 2009 | 08:02 PM
nim81's Avatar
nim81
ya i think piaa's will only work with the vertical style aftermarket grill's .
Old Nov 23, 2009 | 11:43 AM
OlDirtyJohn's Avatar
OlDirtyJohn
on this note... what happened to ALL of the DIYs in the FAQs section? there used to be a ton, and now theres just one.
