P0721 Output Speed Sensor Circuit Malfunction
Old Nov 24, 2009 | 09:16 PM
RubberFrog's Avatar
RubberFrog
Default P0721 Output Speed Sensor Circuit Malfunction
This is an info post for future searches.
There is very little info available regarding this particular code and it took a while to get a straight answer as to how to solve it.
The transmission has two Speed Sensors (not to be confused with the sensor on the diff)- one input and one output. Basically, the input shaft speed is measured, multiplied by the current gear, and then compared to the output shaft speed. This is a diagnostic circuit that is continuously monitored to ensure the trans is performing correctly.
Anyways, the P0721 code indicates a malfunction in the Output Speed Sensor Circuit. The symptoms, aside from the check engine light, include lockout of the overdrive gears and a hard shift into second from first.
The solution is to simply replace the sensor. You can get the sensor for about $30. I replaced the sensor and the code came back after clearing it. Drat. I took it to the dealer, and after two days they found a short in my wiring harness. Luckily it was covered by warranty.
I hope this helps someone in the future.
Old Nov 24, 2009 | 09:25 PM
BadHab1t's Avatar
BadHab1t
very good info frog thanks for sharing.... im sure it will come into good use im glad you also got it taken care of thru your warranty.....saves a headache im sure
