Power Steering Hell
Old Nov 25, 2009 | 11:04 AM
annihil8tion's Avatar
annihil8tion
Default Power Steering Hell
I am replacing another power steering pump/reservoir for the 4th time
2003 1500 107,000 miles
Can some of you guys that are around here a lot summarize whats known about the power steering on these things?
Man this is killing me
Old Nov 25, 2009 | 11:13 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
read this
Old Nov 25, 2009 | 11:59 AM
HammerZ71's Avatar
HammerZ71
yep, seems it's easy to ***** one up during install. These trucks DO NOT have a track record of eating PS pumps, but when one does go, you really got to make sure the replacement is installed correctly...
Old Nov 25, 2009 | 12:07 PM
98cherryram's Avatar
98cherryram
What Hammer said sounds about right, its a very precise install, it has to be on just right, or the smallest amount off could shorten the life of a power steering pump in half or even less. I made the mistake on my old pickup once and ruined a brand new power steering pump, and found out after that how to install one correct.
Old Nov 25, 2009 | 12:23 PM
annihil8tion
Wow.
So you guys recommend that I do this with a dealer because 3rd parties are fin up the pullies?
Old Nov 25, 2009 | 12:47 PM
98cherryram
Just get a pump thats already in one piece. Thats the easiest route.
Old Nov 25, 2009 | 01:35 PM
dirtydog's Avatar
dirtydog
Moderate User
But if the rack has contaminants in it that are causing pump failure....???? You should always flush the rack when installing a new pump. I dunno why nobody ever does it? I would flush your rack at 110kmi regardless.
Old Nov 25, 2009 | 04:40 PM
Gone Fishin's Avatar
Gone Fishin
My pump started making a growling noise near the 115K mark, it would surge when I was turning and such. I flushed the system out with fresh fluid and within a few days, all was back to original operation. The fluid that came out was really nasty and smelled burned too. Make sure you do a good flush, to remove contaminents, and keep an eye on the level for a few days after you get it going again. It took mine a while to work all the air out of the system.
Old Nov 25, 2009 | 05:12 PM
jim swanson's Avatar
jim swanson
just bite the bullet and go to the dealer get it all at one time with the pulley and save a lot of headaches 5 ps pumps in a year
Old Nov 25, 2009 | 06:38 PM
big guy's Avatar
big guy
X 3 on the flush and so simple to do. When I did mine. I used a long straight edge to make certain the pully was lined up with the others.
