30k service?? price, info?
Old Nov 25, 2009 | 05:17 PM
Bigc9164's Avatar
Bigc9164
Default 30k service?? price, info?
i took my truck to a place to get tires rotated, trany fluid, oil change, and diff change, and plugs. and they said it would be like $830??!! so i took my keys and went to the dodge dealer(who should be the most expensive) and they would do it for like $490. am i getting all of the check list of things to do right? and what am i looking to pay for this? thanks again guys!
Old Nov 25, 2009 | 06:22 PM
chambers's Avatar
chambers
Is your truck a manual or automatic? I would do most of that stuff myself, to save some cash and know that it was done right. Other things to do are check your air filter and change your pcv valve which are both things you can easily do yourself.
Old Nov 25, 2009 | 06:44 PM
MikeHTally's Avatar
MikeHTally
Eight plugs: $15, tranny fluid and filter: $25, diff fluid: $62, TB clean: $2, PCV valve: $6, oil change: $25, tire rotate: $0. Total $135. Knowing who did it: priceless.
Old Nov 25, 2009 | 07:34 PM
JOHNSN10's Avatar
JOHNSN10
i just got my tranny fluid and filters changed for $75 at a shop.im doing my own plugs,front and rear diff,oil,and power steering fluid as well as the pcv valve.should be easy.i had the tranny done at a shop b/c its a messy job
Old Nov 25, 2009 | 09:37 PM
Bigc9164's Avatar
Bigc9164
yeah i can do the plugs myself and i usually do my own oil. but if im getting the diff and trans done then i might as well. thanks for the info guys!
