Weight for snow?
Old Nov 26, 2009 | 12:56 PM
Toyman's Avatar
Toyman
Default Weight for snow?
My 2003 is a regular cab and 2 wheel drive, stock rims and no lift , how much weight do i need in the bed for the soon to come winter snow? I do have almost new BFG All terrains
Old Nov 26, 2009 | 01:08 PM
EJM05's Avatar
EJM05
Not sure. Where are you located. Last winter for me I had my stock rims/tires(which had like 60% tread left) on through the whole winter and had no problems. Even though I have a 4x4 I didn't use it. I located in the northern most town in CT. Our winters can get brutal but there is no need to drive in the middle of the storm. I would say just put a couple of sand bags in the bed and you should be fine. I think it might say in the manual. Plus if you do slide you can practice your drifting.
Old Nov 26, 2009 | 01:09 PM
HammerZ71's Avatar
HammerZ71
When I lived up north, I always threw three to four 50 lb. bags of sand between the tire well humps. Even though I have always had 4x4s.
Nice benefit is by using sand, you can always split open a bag and use it to get traction if you get stuck...
Old Nov 26, 2009 | 01:12 PM
Freakinkeith806's Avatar
Freakinkeith806
Yep, get 2 birds with one stone with some sand.
Old Nov 26, 2009 | 01:13 PM
dirtydog's Avatar
dirtydog
Moderate User
Just went yesterday to Home Dumpo and bought 100lbs for the back of my Exploder and 250lbs for my truck.
Being you have a 2wd and a reg cab, I would put 300lbs back there as long as you don't use your bed all the time. if so, then maybe 4 bags(200lbs) would be easier.
I noticed a huge difference with 250lbs back there.
Old Nov 26, 2009 | 04:55 PM
AsphaltCowboy's Avatar
AsphaltCowboy
how much is a bag of sand from homeboy depot?
Old Nov 26, 2009 | 09:01 PM
AK2500's Avatar
AK2500
Default This is what I use
http://www.shurtrax.com/..This product is great. You can stack 500lbs on it without a problem and in the summer you just drain it and it takes up very little space in the garage. With just thee inches of water it add 400lbs directly over the rear axle with no shifting or sliding around.
Old Nov 27, 2009 | 12:41 AM
98cherryram's Avatar
98cherryram
My bed just always has my work equipment in it, I use that for weight, I have about 300lbs of equipment in the bed of my truck at any time, give or take a few pounds.
Old Nov 27, 2009 | 05:58 AM
RubberFrog's Avatar
RubberFrog
I date fat chicks in the winter.
Old Nov 27, 2009 | 09:53 AM
dirtydog's Avatar
dirtydog
Moderate User
200/4=50lbs per bag.
