Sagging front bumper help
I remember a few months ago I saw a thread on this but cant find it anywhere..
My front bumper sags down a bit and there is about an inch or 2 gap between the bumper and head lights.
Can someone post a pic or give me some help on how to raise it?
This should be interesting considering I've got 3 train horns, an air compressor and the air tank on the inside of the front bumper and on the outside of it I have a grill gaurd in my way
Thanks for the help fellas
i had the same problem when i took the bumper off then put it back on. first thing to try is to loosen the 4 bolts holding it on the frame then lift it up as high as it will go and tighten the bolts back up.if that doesnt work then u may have to loosen all the bumper brackets that are attached to the bumper itself and slide then down if u even can. all that holds the bumper on the truck itself is 4 bolts near the center of the truck.
What did you hit?
Seriously, tho, that's what mine looked like after I tapped the rear end of a Tacoma. You know how sometimes you're the #2 car at a stop sign and the #1 car starts to go so then you start looking for your opening and get ready to go and then suddenly realize the a-hole in #1 didn't actually go? Yeah, I hate that.
What did you hit?
