Leveling kit
Old Nov 30, 2009 | 05:27 PM
cheapbeater's Avatar
cheapbeater
crank the torsion bolts.. i raised my front end about 1.5" and it's just about level. and FREE! other than having to buy new shocks or relocators
Old Nov 30, 2009 | 06:52 PM
blackhemi05's Avatar
blackhemi05
well over the long term deal wouldnt it be better to just buy a leveling kit than to crank the tb
Old Nov 30, 2009 | 06:54 PM
cheapbeater
uh... no, they both do the same thing... add tension to the t-bars to create lift
Old Nov 30, 2009 | 07:01 PM
blackhemi05
how high can u lift the front by cranking the tb
Old Nov 30, 2009 | 07:30 PM
cheapbeater
i dont think you can get it up more than 3"... keys might help get it a little higher tho... but if you crank them that far your cv shafts are gunna be at an extreme angle, and it will ride like a lead pipe..
Old Nov 30, 2009 | 09:29 PM
blackhemi05
ok thanks guys what size tires would i be able to run with scrapping when im turned with cranked tb
Old Nov 30, 2009 | 09:45 PM
rochefort978's Avatar
rochefort978
My truck is cranked instead of leveled... I raised mine about 1-1/2 - 2" and still have adjustment left... Just when you do it... Your bolts probably won't be even... Mine aren't anywhere near even but the truck sits level.. And get er' aligned
Old Nov 30, 2009 | 09:56 PM
cheapbeater
35's... depends on your wheel offset tho... i think i have 4.5" backspacing...
Old Nov 30, 2009 | 11:06 PM
blackhemi05
im just gunna keep the stock chrome 20 that came on it and probably run a 33' or 34' tire
Old Dec 1, 2009 | 06:02 PM
AsphaltCowboy's Avatar
AsphaltCowboy
Originally Posted by weedahoe
2/1 will work. I would look for shackles though IMO instead of blocks.
why? my kit will be here tomorrow with the 1.5" rear blocks.
