Leveling kit
Old Nov 30, 2009 | 12:59 AM
blackhemi05's Avatar
blackhemi05
Default Leveling kit
OK i have a 2005 dodge ram 1500 laramie and was wanting to ge a leveling kit to get the truck to sit level. I was just wondering if anyone had any advice on if i should get a 2 inch leveling kit with 1 inch blocks in the back. Or if just a 2in kit would make it even. If anything i wouldnt mind for the front to be a tid bit higher than the back. I want to be able to run 33 inch tires or 34.
Old Nov 30, 2009 | 01:53 AM
Freakinkeith806's Avatar
Freakinkeith806
33'' Tires are stock...I put a 2 inch level on my truck when I put new tires that are equivalent (sp?) to 34's
Old Nov 30, 2009 | 06:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
2/1 will work. I would look for shackles though IMO instead of blocks.
Old Nov 30, 2009 | 07:45 AM
HammerZ71's Avatar
HammerZ71
4x4 or 4x2?
Old Nov 30, 2009 | 11:01 AM
blackhemi05
its a 4x4
Old Nov 30, 2009 | 11:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thats a whole different animal and you need to add that info in your profile so everyone can see it.
Old Nov 30, 2009 | 01:12 PM
blackhemi05
well i added my info in my profile. hopefully i can get some good information on what the best way is to get the look that i want with the leveling kit. thanks for all the help so far guys.
Old Nov 30, 2009 | 01:54 PM
Stormin264's Avatar
Stormin264
i installed the 2in leveling keys a month or so ago. it leveled it out nicely. didnt do any blocks or lift in the rear.
Old Nov 30, 2009 | 04:11 PM
98cherryram's Avatar
98cherryram
I put a 2.5 inch leveling kit in the front and 1.5 inch add a leaf in the rear and I comfortably fit a 35X12.5 with a wheel of the right offset.
Old Nov 30, 2009 | 05:03 PM
HammerZ71's Avatar
HammerZ71
With your torsion bar system it takes about 2.25-2.5" to make the truck level. You can either crank the torsion bolts for a free lifts or purchase and install the leveling keys...
