3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Just curious as to how you all rotate your tires? Do you "X" the back two to the front and slide the fronts to the back (like the manual says) or do you just "X" all four tires?
i doesn't really matter. typically on a RWD vehicle you X the fronts and move the rears to the front. FWD you X rears and move the fronts to rears. AWD you X them all. But as long as you do either of these your fine, it doesn't really matter.
True unless you have directional tires, meaning they can only be a passenger or a driver's side tire. Then you just go back and forth.
