'06 throttle position sensor?
does a '06 hemi have a throttle position sensor? i cleaned my throttle body and now that its back on, it seems like i have to push the gas pedal down farther to get the truck to move. anyone have any idea what it could be? im not throwing a code and i have rebooted the computer a few times now with no luck.
Brad
Brad
Here we go again. There is no calibration procedure for a Hemi throttle body as it does this each time the key is turned on. Your truck will have a throttle position sensor built into the throttle body and is not adjustable nor replaceable. There is also an accelerator pedal position sensor located below the battery tray inside the engine compartment. Which code exactly are you getting?
thats the thing...im not getting a code. i just know that i can push the pedal down about 1/4" before the rpms move at all. all i did was clean the throttle body and this happened right after i reinstalled it.
