Coolant problem
Old Dec 4, 2009 | 10:53 AM
06RAM-KC's Avatar
06RAM-KC
Default Coolant problem
I have a 2006 Ram 1500 with the 5.7. In the past few months my truck has been going through coolant rather quickly, I go from the full line on my reservoir to the add line in a matter of 3 weeks. I don’t have any puddles under my truck and I don’t smell anything sweet coming out of the exhaust. Does anyone else have this problem or is this just something the HEMIs do? Thanks for all the help.
Old Dec 4, 2009 | 12:53 PM
2006NightRunner's Avatar
2006NightRunner
You shouldn't have to keep adding coolant. I would pressurize the cooling system and start looking for leaks. If you don't see any external leaks, it may be leaking internally, past a head gasket, etc.
Old Dec 4, 2009 | 12:56 PM
MoparRamMan's Avatar
MoparRamMan
Check your oil if its milky you have a blown head gasket.
Old Dec 4, 2009 | 01:17 PM
06RAM-KC's Avatar
06RAM-KC
oil is fine, its not mixing there
Old Dec 4, 2009 | 02:43 PM
RubberFrog's Avatar
RubberFrog
It's probably blowing into the combustion chamber. Sounds like a pretty small leak, it probably wouldn't be enough to smell in the exhaust. Do a pressure test on your radiator.
Old Dec 4, 2009 | 02:53 PM
05RamMan's Avatar
05RamMan
Go with the simple stuf first And hope its just a leak somewhere.
