How many quart of oil can you drain from 5.7 hemi engine?
Old Dec 6, 2009 | 03:20 AM
wshtb's Avatar
wshtb
Default How many quart of oil can you drain from 5.7 hemi engine?
I was only able to get about 5qt of fluid in the waste bottle. Granted there are still some oil absorbed in the filter, this is far less than the official 7qt capacity. Also it took less than 6qt of new oil to raise the oil level between min and max.
How much oil can you drained from the 5.7L hemi engine? I'm worried about leaving a full quart of dirty oil in the engine.
Old Dec 6, 2009 | 03:25 AM
irelandshemi's Avatar
irelandshemi
not sure on how much you can get out but im right around 6 1/2 to where im at max after my oil changes
Old Dec 6, 2009 | 09:27 AM
MikeHTally's Avatar
MikeHTally
I've never measured how much comes out. I just let it drain a long time to get the maximum out. When I refill, I put oil in the filter before I attach it. I put in five quarts and check the stick, adding 'til it's at the "max" indicator.
For a guess, I'd say half-a-quart remains in the galleries and clinging to surfaces.
Old Dec 6, 2009 | 10:04 AM
DodgeThunder's Avatar
DodgeThunder
I noticed this to when I do my oil changes, Im always about 1/2 - 1 litre short from what I put in to what I get out.. But my truck has never gone below the max line, I check it before I do the oil change, I just cant figure out where it goes..
Old Dec 6, 2009 | 11:20 AM
dirtydog's Avatar
dirtydog
Moderate User
There will always be some oil left in the engine that won't come out with a normal drain. You cannot measure how much comes out unless you have a specific measuring device and checked your dipstick level to see if you've burned any oil... Also, the oil filter holds a bit of oil.
Old Dec 6, 2009 | 11:57 AM
lxman1's Avatar
lxman1
Site Moderator
Whatever the dealer drains out
You will never get the full capacity out of any engine. There is always oil laying in passages, on the lifter valley, in the lifters themselves, in the heads, etc.
Usually if the engine holds 6qts, you will usually fill a gallon jug with the drained oil.
