Purge Solenoid
Old Dec 7, 2009 | 04:50 PM
tafet's Avatar
tafet
Default Purge Solenoid
My check engine light popped on the other day. I did the key trick and was able to pull the P0441 code for an evap issue. Is there a way to check the operation of the purge solenoid before I go back and lye down on the wet ground to check the vacuum lines by the purge canaster? Thanks.
Old Dec 10, 2009 | 07:51 PM
DM1's Avatar
DM1
your purge valve should be in the engine compartment around the line with the green service cap. Check to see if any vacuum lines are not connected in the engine bay. the only way to activate the valve is through dodge's diag scanner.
