Metal on metal noise when 4wd is engaged
Old Dec 8, 2009 | 12:54 AM
WWJD's Avatar
WWJD
Default Metal on metal noise when 4wd is engaged
No matter if it's 4 wheel high or low when I move a loud metal clanking noise occurs. It is pretty high pitched and has been making me worry.
Any thoughts?
Old Dec 8, 2009 | 12:59 AM
hemiguy0302's Avatar
hemiguy0302
Sounds like your t case or front diff turned into metal hamburger. When was the last service performed?
Old Dec 8, 2009 | 01:43 AM
WWJD's Avatar
WWJD
Probably so, when I bought the truck I had an extra grand to get a head start on some routine but before I could get in to doing anything my tranny needed a rebuild.
from the looks of the rear diff fluid I would say never. I am so nervous about my truck right now. I just know something is around the corner. Money is an object.
Old Dec 8, 2009 | 01:51 AM
Ice-Forever's Avatar
Ice-Forever
sell it before it breaks and buy a new one lol
Old Dec 8, 2009 | 01:59 AM
WWJD's Avatar
WWJD
you don't know how much I have been considering this.
Old Jan 5, 2010 | 03:50 PM
WWJD's Avatar
WWJD
I am brining this one back up because my diff turned out good. Waiting to do the T case.
I wanted to add that there is also a rattle noise coming from the front when at any speed. At highway speeds I can here it in cab.
any guess's. I thought maybe a CV joint or something.
Old Jan 5, 2010 | 03:53 PM
dirtydog's Avatar
dirtydog
Moderate User
if the sound is only when 4wd is engaged, then it's likely your T-case as your ftont diff is constantly spinning even in 2wd.
Rattle noise is not likely a CV but something else. Someone posted up the other day about the hood bumpers not keeping the hood solid and was causing a rattle. Something to check out.
Old Jan 5, 2010 | 04:53 PM
RubberFrog's Avatar
RubberFrog
sounds fubar
Have you even checked to see if there is any fluid in the tcase?
Old Jan 6, 2010 | 06:54 AM
WWJD's Avatar
WWJD
Sometimes, from a complete stop it will make the same noise that it does when the 4wd is on. I only noticed this yesterday. I was hoping someone may have had the same problem(s). I keep thinking they are related because the tones are nearly the same.
I think I am going to let this thread die once and for all. Unless I can get like a video with sound or something.
