sand bags in a 4X4??
Old Dec 9, 2009 | 09:18 PM
offroadjosh's Avatar
offroadjosh
I run about 250lb plus my topper, 2 sets of tire chains and a few presto logs. Handles pretty good in the snow. Also got 4x4 with a powertrax in the rear and soon to be an ARB up front =P(i hope)
Josh
Old Dec 10, 2009 | 01:04 AM
Kamel87's Avatar
Kamel87
can i just say idk how long you had those coopers but im on my second pair and they are AWSOME in the snow they grip like no other tire i ever had. i was thinking of putting some sand bags or salt bags but if your careful you really dont need them
Old Dec 10, 2009 | 01:21 AM
Got_Hemi44's Avatar
Got_Hemi44
Originally Posted by suzuki750
Got Hemi44,how did u build your box?? Did u just build it to sandwhich between the wheel wells out of 2x4's. Sounds like a good idea to keep them from sliding around, i might have to do that
I'll take some pics tomorrow.
Old Dec 10, 2009 | 09:05 AM
Lifted4x4Astro's Avatar
Lifted4x4Astro
Talking
I run over 700# in the back of my 2500. It is mostly ballast weight for the snow plow, but definitely helps with traction in 2WD. My 12.5" wide tires are not the best in snow even though they are new. I have Cooper Discoverer S/T's. Narrow tires are better but look silly on a 2500.
Old Dec 10, 2009 | 09:09 AM
HammerZ71's Avatar
HammerZ71
I never ran that much, two or three 50# bags just inside each tire hump was what I would put in. I'd always load the sand bags into a big, super heavy duty platic bag, because if it gets wet, you can forget about using it for traction as it basically turns to concrete...
Old Dec 10, 2009 | 09:20 AM
dirtydog's Avatar
dirtydog
Moderate User
I have a 1500. I running 4 sandbags directly over the axle. 200#'s. last year I ran 300#'s but the extra 2 bags were a PIA because I use my bed to run my snowblower up in there. Moving the bags around was getting old. Especially since they STICK/FREEZE to the mat. No box or frame is really necessary if you have a bed mat. My bags stuck to the mat on a regular basis.
I took 2 bags and slid them into a 3mil garbage bag to keep the weather out from bursting the bags. Even with them in the slick garbage bag, they do not move around.
1500 series can run up to 300#'s before the bed starts sagging and the suspension feels the weight.
2500 can prob take a good pounding like 600lbs before anything begins to sag.
I ran 300#'s last year, but I keep a full tank of gas all the time which is added weight right there so this year i dropped down to 4 bags instead of 6. You can get 4 bags and have them in the far back corners. The extra 2ft of leverage makes the 4 bags feel like 6 that are directly over the axle.
Old Dec 10, 2009 | 09:27 AM
02Steve1990's Avatar
02Steve1990
I think I may throw some bags in the bed this year too
