Proper Way To Drive On Ice?
Old Dec 10, 2009 | 05:30 PM
02Steve1990's Avatar
02Steve1990
Originally Posted by Brado34
So today i hit a curb. busted my wheel...
i was wondering what i have to do to drive in the ice.
i was in 2wd i know stupid on my part..
but anyways on the way home frm school i pressed the break and skidded about 10 feet. i wasnt going fast at all. and also i was in 4x4.
Wait..what?
hemiguy0302's Avatar
hemiguy0302
I always run in 2wd on ice unless I need to accelerate faster(slow city driving or highway driving 4wd is engaged). By having it in 2wd the trucks ABS is able to function better and keep you on the right course. Leave atleast 3x the gap between cars you normally do more gap is better. Basically you need to visualized an egg on you gas and brake pedal. Smash the egg your going too fast.
Old Dec 10, 2009 | 06:11 PM
OklaHemi's Avatar
OklaHemi
i dont know how good it is on the tranny but when i had my envoy and was in colorado i would drive slower and let off the gas like everone has said but if i needed to stop i would down shift the envoy to first and let the engine slow it down. it saved my *** plenty of times
Old Dec 10, 2009 | 06:19 PM
hemiguy0302
Yes it does work but in extreme ice if you were not careful would it not lock up or really slow down the rear wheels too quick causing a spin or were you rocking 4wd.
Old Dec 10, 2009 | 06:21 PM
AF_HEMI's Avatar
AF_HEMI
downshifting is no different than upshifting from the trannys point of view. downshifting is actually healthy for the engine so long as the rpm's dont go unusually high
Old Dec 10, 2009 | 06:55 PM
RubberFrog's Avatar
RubberFrog
Originally Posted by 02Steve1990
Wait..what?
Good catch. Which was it?
Old Dec 10, 2009 | 08:26 PM
Mega-Hemi's Avatar
Mega-Hemi
Just to add to this, downshifting too fast could cause what is called a "compression skid". The engine causes the tires to slow faster than the vehicle speed and breaks traction anyway. If you're not used to driving on ice, your best bet is to freewheel. If you're driving a stick, push the clutch. If driving an auto, pop it in neutral. A free wheeling tire is more likely to grab traction than a tire that is being controlled by engine speed. Now, after you get some experience under your belt, and can match your tire speed to road speed, you'll learn how to feather the throttle out of a skid. It's not a bad idea to put it in "N" when coming to a light or stop sign either. I'm not sure how the newer trucks are set up, but, older vehicles had like a 70-30 split braking force. I've seen guys, with the front brakes locked, Idle through an intersection wondering why thier truck is still moving. I don't think it's as much of a problem now with our 4 wheel discs.
Old Dec 10, 2009 | 08:56 PM
dodgenitto's Avatar
dodgenitto
Being in 4WD does absolutely nothing to help with braking.
Old Dec 10, 2009 | 10:21 PM
05RamMan's Avatar
05RamMan
He is saying he was driving a 4wd truck in 2wd mode.
If you want to learn how to drive on ice, Find a large open empty lot that is iced over and have some fun. It is really fun to do in pegleg trucks.Thats How I learned. just after I learned how to drive my dad took me out to a mall parking lot at about 3am the first time there was significant amount of ice on the ground, Gave me the keys and said have at it. 3 hours later I feel I could drive anything on ice anywhere and have proven it many time over. The first thing you will learn is that ice is not predictable, however, Newton's First Law of Motion is.
Old Dec 11, 2009 | 09:49 AM
OklaHemi's Avatar
OklaHemi
i never just slammed into first and i usually had it in 2nd coming off of a frozen mountian any way. i guess i was never going fast enough to cause a skid. i usually had it in 4 wheel auto.
