Tire Rubbing bad
Old Dec 11, 2009 | 06:54 PM
Spyderman's Avatar
Spyderman
Default Tire Rubbing bad
I just put on my lift, wheels and tires a couple of weeks ago. The lift was 3" front and 2" in the rear. The tires are 325/65 Cooper Discoverer STT's on 18" Moto Metal 957's. They are rubbing really bad. I am thinking that the only way to fix it is to buy a taller lift. Any suggestions?
Attached Thumbnails Tire Rubbing bad-07-dodge-007.jpg   Tire Rubbing bad-07-dodge-009.jpg
Old Dec 11, 2009 | 07:51 PM
HammerZ71's Avatar
HammerZ71
it's hard to tell from your pic, small pic coupled with my 40+ year old eyes. Where is the rub and what are your wheel specs? Could simply be your wheels are more street (lowered) specs, without a negative offset nor the backspacing required to clear...
Old Dec 11, 2009 | 08:02 PM
dodgenitto's Avatar
dodgenitto
What he said + if it is just rubbing the plastic on turns you can buy a heat gun and remold your plastic wheel well liner??
Old Dec 11, 2009 | 08:49 PM
Got_Hemi44's Avatar
Got_Hemi44
You bought a tire that is too wide. Your lift has no effect on it.
Old Dec 11, 2009 | 10:08 PM
HammerZ71's Avatar
HammerZ71
Hence why I suspect he's got a wheel without a negative offset nor backspacing...
Old Dec 11, 2009 | 10:41 PM
oefootball_70's Avatar
oefootball_70
put 1.5 inch spacer on it.
Old Dec 11, 2009 | 10:49 PM
OSO's Avatar
OSO
Yes more details and bigger pictures and some new ones of where its rubbing .
Old Dec 11, 2009 | 11:14 PM
Got_Hemi44's Avatar
Got_Hemi44
It's obviouly not a diameter issue since he has 3" lift and a 34" tire. A 325 is too wide for our trucks. Anything over a 305 will 99% rub the uca. What he needs too do is sell his tires and buy some that fit. Don't put spacers that's retarded.
Old Dec 11, 2009 | 11:22 PM
OSO's Avatar
OSO
Its all about correct back spacing. Cant remember who but somebody makes a UCA that is curved for more clearance well i know they do for the PW.
Old Dec 11, 2009 | 11:37 PM
JoeHemi's Avatar
JoeHemi
I'll help him on the pics....
