More Nitto tire Q's
Old Dec 14, 2009 | 07:18 PM
Beastro's Avatar
Beastro
Default More Nitto tire Q's
I have the stock 20in rims on my 04 ram I want to put 31's on them.I see every 1 is useing nitto's so i went to there site and the do not have 31's looked at the bfg site and found 31's but nor for 20in rims. So my question is can i even put 31's on my 20's. i want an all-terrain tire and a good brand no cheapo's
Old Dec 14, 2009 | 07:35 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Nitto does make the terra grappler, an all terrain tire in sizes 265/50/20 which is just under a 31 and also 275/55/20 which is almost a 32 but not quite it's not much difference. The 275 tire is like 31.9. It will fit, but you know you can definately go larger than 31 if you want nitto's on your stocker rims. The regular sizes can be equal to the inch tires you're looking at. Plus, if you get the 275 type tires, they're normally cheaper than the 31 type floatation tire you're looking at.
Old Dec 14, 2009 | 07:41 PM
cheapbeater's Avatar
cheapbeater
stock tire size on the 20's is 33"... maybe that will help you find a tire...
Old Dec 14, 2009 | 08:05 PM
Beastro's Avatar
Beastro
Well that helps a lot. So the stock tire size is 33s. Is there a chart out there or something to figure tire sizes. Are nitto's the better brand out there or is it opinon
Old Dec 14, 2009 | 08:12 PM
02Steve1990's Avatar
02Steve1990
I have something to add rather than make another thread. I know a ram can fit a 33" tire (285/70R17) at stock height but that specific measurement has either an 11.46 or basically 11.5" width, can I fit that width under stock height?
edit: These will be NTG's
Old Dec 14, 2009 | 08:13 PM
cwboyjohnny24
It's all personal preference on what kind of tire. It's also about what look you like. Look at tirerack.com or tires.com they will both have tire calculators and tell you what you need to know.
Old Dec 14, 2009 | 08:15 PM
cwboyjohnny24
yes, that can fit under stock 4x4 height. I'm not sure about 2wd stock height. Should be no rubbing.
Beastro's Avatar
Beastro
Sweet deal thanks
Old Dec 14, 2009 | 08:18 PM
cwboyjohnny24
good luck, show us some pics when you decide what to go with.
Old Dec 15, 2009 | 12:02 AM
justanothermoparman's Avatar
justanothermoparman
275 is the width while 50 is the hight, I have 275/65 20 which is 34.07 tall.
