help, remote start
Old Dec 20, 2009 | 10:42 AM
dirtydog's Avatar
dirtydog
Moderate User
Problem about the 5101 is that it's strickly a Remote start set-up and has a one buttone remote. Has no siren or shock sensor and no lock/unlock/panic buttons. You can get away with no siren(use the horn) but you'll have to buy a shock sensor. ($20 shipped off ebay) You will have to carry around your original key fobb to lock/unlock(arm/disarm) the system.
As far as the bypass, using a bypass is actually easier as far as the install goes than installing an alarm/starter without one. The bypass actually learnes everything and needs very few hook-ups. There are bypass's that use NO key but you need 2 programmed keys to program it.
Took me about 3 hours for my install in my truck.
Old Dec 20, 2009 | 11:16 AM
dirtydog's Avatar
dirtydog
Moderate User
I only say it's a "problem" is because it seems that in your last post it seems like you would want to protect your amps + stuff....You'll just need to carry two remotes around is all.
it's very easy to upgrade even entire remote starters/alarms a few years down the road. it's actually easier because all your connections have already been made.
I picked up a basic remote start for my Exploder because it was all i wanted. i won the bid for $26.01 plus $5 shipping AND i don't even need a bypass cuz Ferd didn't put PATS in the Exploders until '98 and i got a '97...hehe.
Maybe you can squeeze out a extra bucks for THIS Just remember you would still need the bypass that runs like $40-50 alone. Way overpriced because they know you'll buy it....have to buy it....lol HERE is the bypass you want.
Old Dec 20, 2009 | 11:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
But dog, RS dont have accessory ports for add-ons like shocks sensors do they? I wouldnt think so. The most it will have is a pin switch for the hood.
Old Dec 20, 2009 | 12:04 PM
dirtydog's Avatar
dirtydog
Moderate User
The one I just installed in my Exploder does. It's an Ultra Start GX-11R???
Has an expansion interface port, shock sensor port, datalink port and a bypass port.
Old Dec 20, 2009 | 01:24 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Interesting, so it could act as a trigger switch or pin switch and cut off the RS if "sensed" huh? I guess thats cool
Old Dec 20, 2009 | 08:29 PM
jms2291's Avatar
jms2291
so y do i need 2 clickers?
my remote start has a lock and unlock button, it has 5 buttons...
and as far as the get together i might try to come, that sounds cool...
