4wd indicator light flashing????
I was trying to **** my truck in 4wd today and it def feels like it shifted but the 4wd indicator light keeps flashing instead of staying illuminated. I tried shutting the truck off and trying it again and nothing seems to work. I have an 08 with the electronic shift ****. Anyone had this problem. I have 35" tires and i think that might have something to do with it. Please help guys, my truck was just in for the 15k service 2 days ago and i dont want to go back if i dont have to.
thanks
thanks
try putting it in neutral and turning the ****. my wifes old envoy did that when shifting to 4lo it would blink so i had to put it into n and turn the **** back to 2w and then to 4lo i hope this helps. i know you can shift to 4hi on the fly in our trucks but i dont know about the 4lo
i always shift it from a stand still in neutral. I took it for a test drive in the snow it was def in 4wd because it felt very confident around tight corners with nearly 10" of snow. Im going to call the dealership in the morning to figure this out. Thanks for the suggestions guys.
I've shifted on the fly before at 65mph into and out of 4hi. No probems at all. Super smooth can't even tell. Did it on my last truck and this one. 65 is a bit fast, but just wanted to show it does no harm. (I think the book says something like up to 55mph???)
I'd guess it's a sensor if it's actually engaging. Either a loose wire or bad sensor.
