More MPG, 05 Ram 1500 5.7L
Old 12-24-2009, 06:18 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
He meant 5 mph.....not 5 mpg
  #62
Old 12-24-2009, 07:36 PM
Ketch21's Avatar
Ketch21
Ketch21 is offline
hahaha
  #63
Old 12-24-2009, 10:14 PM
TheFist's Avatar
TheFist
TheFist is offline
5 is all you got from yours!? I got like, 18mpg with mine.
  #64
Old 12-27-2009, 11:07 PM
Dodge180's Avatar
Dodge180
Dodge180 is offline
For those E Fans, do you remove your old fan shroud aswell as fan and do you have to relocate your coolant/windshield washer resevoir at all?
  #65
Old 12-27-2009, 11:35 PM
rcman0056's Avatar
rcman0056
rcman0056 is offline
Change plugs, Cleaned throttle body, Royal Purple in rear end, new gas cap(could hear it leaking pressure) Got another 2 mpg or so. Get a bike!
  #66
Old 12-28-2009, 05:31 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Moes makes a shrouds delete kit which is basically two different bottles made to go else where. It is a very expensive kit IMO.
However, when i did mine I mounted it to the rad and then put the shroud back over it.
  #67
Old 12-28-2009, 02:44 PM
chambers's Avatar
chambers
chambers is offline
I did mine like Weed, it's cheaper and the shroud is important b/c it helps direct airflow over the entire radiator.
  #68
Old 12-28-2009, 04:50 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I would post pics of mine but I dropped my cam and broke the flash. :-(
Quick Reply: More MPG, 05 Ram 1500 5.7L
