Weird noise/possible issue
Old Dec 22, 2009 | 09:52 AM
TRXHemi's Avatar
TRXHemi
Question Weird noise/possible issue
2008 4.7 5-speed auto 33K miles....
Just started a couple of days ago...I hear a weird hissing (best described) noise when accelerating. It seems to happen in the lower rpm range. When I give it about half throttle or more, the noise goes away. You can hear the noise rise and fall with the throttle, but again, it only seems to be happening below 2000 rpms....When I am stopped and give it gas, I do not seem to hear it.
Not sure if it is exhaust related, rear end related, transmission related??
Any ideas or thoughts??
Old Dec 22, 2009 | 11:43 AM
dirtydog's Avatar
dirtydog
Moderate User
What kind of intake you got? Sounds like an intake dealio...One of them there noisey ones???
Old Dec 22, 2009 | 11:47 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Thats what I would guess. Does it sometimes almost sound like a blow off valve?
Old Dec 22, 2009 | 12:26 PM
TRXHemi's Avatar
TRXHemi
Stock airbox.....K&N drop-in.....and it just started. I have had the truck for a year and a half....seems to be coming from the rear of the truck...
Old Dec 22, 2009 | 03:44 PM
TRXHemi's Avatar
TRXHemi
bump - anyone??
Old Dec 22, 2009 | 03:50 PM
chambers's Avatar
chambers
It could be the rear end although it will typically make a whining/whirring noise. Has your truck recently been regeared or had any work done to the rear?
Old Dec 22, 2009 | 05:07 PM
TRXHemi's Avatar
TRXHemi
I had 4.10s installed about 9K miles ago.
Old Dec 22, 2009 | 05:33 PM
chambers's Avatar
chambers
I would think that an issue w/ it would have come up before now then. Who did the install, maybe call them and describe what you're hearing. Also check your differential fluid level, hopefully it's nothing.
Old Dec 22, 2009 | 07:30 PM
whipkeysd's Avatar
whipkeysd
I have the same truck as you only auto with close to 20,000 miles and have also noticed this hissing while accelerating at lower rpms. On mine it sounds like it's coming for the passenger side under the hood maybe. It just started one day and has kinda bugged me. I was gone for 2 weeks and just got back and haven't noticed it in the past couple of days so I'll have to see if I notice it. If this is the same problem maybe someone will come up with an idea. I'll look mine over tomorrow.
Old Dec 22, 2009 | 09:55 PM
TRXHemi's Avatar
TRXHemi
Mine is automatic as well - the 5-speed auto......kind of weird....
