Gears for 4x4's??
Old Dec 23, 2009 | 12:31 AM
Dawizman's Avatar
Dawizman
Originally Posted by ramhunter9
nahhhh go 4:10 you wil love it
4.10 is a nice ratio, however 4.56's are better when running 35in tires though.
Old Dec 23, 2009 | 12:45 AM
OlDirtyJohn's Avatar
OlDirtyJohn
now that i have 4.56s, i kinda wish i woulda gone 4.88. 2wds can run 4.88s, 4wds cannot in the stock carrier.
Old Dec 23, 2009 | 10:16 AM
HammerZ71's Avatar
HammerZ71
For 35" tires and an automatic transmission with essentially two overdrives, you don't need to consider anything less than 4.56 gearing.
And technically you can do just the rear, but I'd recommend disconnecting the front driveshaft, cause if you even accidentally bump the thing into 4x4 mode, the flatbed man will have to go back to get your transfer case off the road AFTER he loads your truck up!!!
Wait till you've saved enough pennies up to do both if you have to, DO NOT just do the rear gears...
Old Dec 23, 2009 | 10:52 AM
EJM05's Avatar
EJM05
so should i do gears before the lift. and yes i do use 4x4 alot in the winter. or can i do the lift and run stock gears?
Old Dec 23, 2009 | 11:12 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
ideally gears before lift/tires. but stock gears with 35s isn't the end of the world. you'll still be able to get around find, will just feel sluggish.
Old Dec 23, 2009 | 11:22 AM
HammerZ71's Avatar
HammerZ71
IMO it depends on if those stock gears are 3.55 or 3.92s...
Old Dec 23, 2009 | 01:17 PM
ramhunter9's Avatar
ramhunter9
agreed
Old Dec 23, 2009 | 01:27 PM
snowhill's Avatar
snowhill
I have 35" tire on 17" wheel and 3.92 gears. It works very well, but i would love 4.56
Old Dec 23, 2009 | 02:26 PM
EJM05's Avatar
EJM05
is there anyway to find out which ones I have?
Old Dec 23, 2009 | 02:33 PM
Got_Hemi44's Avatar
Got_Hemi44
I had only the rears done for about 2 months lol. Did the fronts a little bit ago with winter coming up.
