2.5 leveling kit question?
Old Dec 24, 2009 | 06:12 PM
Desert_Ram's Avatar
Desert_Ram
Default 2.5 leveling kit question?
i have a 03 1500 2wd looking for a 2.5 leveling spacer does anybody know where i can get them? i have only been able to find a 2" any help would be appreciated!
Old Dec 24, 2009 | 06:15 PM
explorer9950's Avatar
explorer9950
here ya go...
http://www.autotrucktoys.com/ram/Day...8453C4675.aspx
this will fit you truck, I have these in my 07 1500...leveled out perfectly, even appears nose high sometimes, but barely noticeable...
Old Dec 24, 2009 | 06:22 PM
Desert_Ram's Avatar
Desert_Ram
i have found this one in the fitment guide it says 94 -01 1500 will this matter or will it still work?
Old Dec 24, 2009 | 07:30 PM
explorer9950
Nope...it will still work, I have this kit on my 07 1500...
Old Dec 24, 2009 | 07:51 PM
Ice-Forever's Avatar
Ice-Forever
I believe different years have different things, like my truck takes torsion keys, some models you have to replace spindles or something I think?
I'm not %100 sure, i just know what MY truck needs, but you might want to make sure you get the one for your year of truck just to be on the safe side...
I believe yours also needs torsion keys, I wanna say it was 02-05, but again, not %100 sure
edit: Also, mine is a 4x4, which might also change things. Like I said, just make sure you are getting the right ones before you order them so that you don't get the wrong item.
Old Dec 24, 2009 | 08:26 PM
explorer9950
Nope...if your truck was a 4x4 then yes, you have torsion bars. But his is a 2wd, the spacers I showed him will work!!
Old Dec 24, 2009 | 10:16 PM
sharkhunter10's Avatar
sharkhunter10
yes those spacers will work they work on my 07 to
Old Dec 28, 2009 | 04:31 PM
slapshot12's Avatar
slapshot12
Are they as easy to install as they seem? I see they are offered in 1", 1.5", and 2". Is it only the 2" that requires longer shocks? I want to level the ride on my 07, but can't lower the rear due to the towing the boat.
Old Dec 28, 2009 | 04:35 PM
fk1022's Avatar
fk1022
ya you should get an alignment after
