Popping from front end. Help please
My ram has 84k on it now and after the big snow storm we had it has been making a random popping sound every so often and will make a strange howl/growl sound sometimes when i make a slight turn. Its not very loud when it happens. I think its coming from the drivers side.
Its not in 4wd. It does it more on bumpy roads. The truck doesnt pull or drive different at all.
I think its the front hub, but anyone have any suggestions?
just change the hub and bearing set! haha I was just trying to figure this same issue out wuth a guy who had the same problem only in a 3500. he changed out the hub and bearings, no more problem, check it out......
https://dodgeforum.com/forum/3rd-gen...ont-right.html
Trending Topics
You say you think it's the driver side...Does it make the noise when turning left or right? Left would mean right bearing and right would mean left bearing. Bad Bbarings make whine noises when weight is transferred to them. This is if it's actually the bearing itself.
I would eliminate the possibilities of your balljoints/tierods or strut mounts at this time.
I would say it's not the CV's. If you had a CV going bad, you would hear a clicking noise constantly when you turn. But I'm with dog, check out the obvious before going all in on a hub/bearing.
I have a similar situation. When i back out of my garage or parking spot, the truck whines slightly and then POP, the pop is so loud it sounds like im hitting something. It vibrates the whole truck. Dodge says nothing is wrong with it but last time i checked a truck doesnt feel like it is going to fall apart when everything is okay...... any input?
