Rear axle leak help?
Old Dec 30, 2009 | 09:57 AM
stuntpilot's Avatar
stuntpilot
Default Rear axle leak help?
Hi
Recently my rear axle has started to leak from the front pinion. Although it's not a bad leak, i.e. it doesn't drip and the fluid level doesn't drop, the sulfur in the oil is making my truck smell! It smells like it's just been pulled out of the wreckers! I want to change the seal myself but I need to know if the preload on the input is set by a crush sleeve or shims? If it's shims then it's an easy job, if it's a crush sleeve then I have to reset the pinion preload and it's a pita! Does anyone here know? I have an 02 1500 5.9 Magnum slt quad cab, long bed with a posi drive rear axle.
Thank you!
Old Dec 30, 2009 | 01:42 PM
Mega-Hemi's Avatar
Mega-Hemi
The pinion depth is set by shims, the preload is set by a crush sleeve. That's what my LSD is, I think all 9.25's are the same.
Old Dec 30, 2009 | 03:17 PM
stuntpilot's Avatar
stuntpilot
I take it that means that if I were to remove the yoke to change the seal I would have to replace the crush sleeve and reset the preload?
Old Dec 30, 2009 | 03:20 PM
Mega-Hemi's Avatar
Mega-Hemi
I didn't, I just put the old crush sleeve back in and torqued it down, that was 30k ago. My LSD is acting up but I don't think that has anything to do with the pinion, last I checked it there still wasn't any play in it.
Old Dec 30, 2009 | 03:56 PM
BEAR's Avatar
BEAR
here ya go, https://dodgeforum.com/forum/3rd-gen...ty-or-diy.html , this is what I used when I replaced mine.
Old Dec 30, 2009 | 04:13 PM
stuntpilot's Avatar
stuntpilot
Yes but knowing my luck...........................
I'll wait until I hit 100k. Thanks guys for your advice
Old Dec 30, 2009 | 04:21 PM
stuntpilot's Avatar
stuntpilot
Just read Dirtydogs post on the subject!
Thanks guys you have just saved me $80!!!!
