stero system help
Old Jan 3, 2010 | 08:23 PM
chevysucks's Avatar
chevysucks
Default stero system help
First i have a newer alpine HU cant remember what model off the top of my head!, i use to have the thunderform mtx 10"s with built in amp but sold them to a friend.
well now with tax time i want something better i have searched on here for different topics but cant seem to find exactly what i am looking for!!
I want a system that sounds good with everything from rock, hip hop, country, etc!! but want something that hits harder then the 10s i had, have been looking at the alpine type r's , just cant seem to find the right box for them also can get a smoking deal on some JL Audio 10w6 but i am not sure if they will fit under the seat??? looking to spend $1000 or less???
anyone got any ideas???
Old Jan 3, 2010 | 08:47 PM
kx250frider617's Avatar
kx250frider617
w6's wont fit under the back seat. best bet is to either get a fox box under the back seat and fit two type r's or but a jl stealth box with one 10 w0 or biuld your own. Here's my setup.
https://dodgeforum.com/forum/3rd-gen...m-buildup.html
Old Jan 3, 2010 | 09:16 PM
chevysucks's Avatar
chevysucks
k i looked thru your build would that be in the price range??? or would i need to spend a little more to do what i want done???
Old Jan 3, 2010 | 09:34 PM
chevysucks's Avatar
chevysucks
so would this box http://cgi.ebay.com/DODGE-RAM-10-QUA...item48389d6cda
or is this box better??? http://cgi.ebay.com/DODGE-RAM-QUADCA...item3efaff62b5
work with these subs???http://cgi.ebay.com/2-ALPINE-SWR-104...item45efdb18eb
so what amp would i need to power these???
Old Jan 4, 2010 | 03:05 AM
kx250frider617
id say the first sealed box. bandpass boxes are very complicated and need to be perfectly tuned to the sub etc or they sound bad. the box itself is very small with no airspace which is the reason i built my own with around 1.5 cu ft for each sub. the more air the better but not too big. The type R's are what i have, make sure you get a DUAL 2ohm voice coil sub that way you can wire both subs to one amp at a 2ohm. If you are new to audio it may sound complicated but it really isn't. For the amp, get the alpine mrp-m1000. The reason i have two mrp-m500 is becuase I had one amp and one sub at one point and didnt feel like everything. it will be way less than $1000 just buy off of onlinecarstereo.com
Old Jan 4, 2010 | 07:55 PM
Jonhyboi's Avatar
Jonhyboi
Alpine type r's. you won't be sorry. I have them in a ported box in my truck.
Old Jan 4, 2010 | 08:22 PM
Thatonekidw/theHEMI's Avatar
Thatonekidw/theHEMI
jl steathbox. pricey yes but well worth the money.
