100K Mile Maintenance ???
Old 01-04-2010 | 01:30 PM
jgdakotanc's Avatar
jgdakotanc
Exclamation 100K Mile Maintenance ???
2003 Dodge Ram 1500 turned over 100K a few weeks ago. I have changed the oil every 5K and everthing else has worked fine, so nothing more has been done. I wanted to ask what if anything should I do now since it has a few miles on in. Ex. Coolant flush, Tranny Flush, Fuel Filter, Rearend Grease, etc. ??? Truck has run great and just want to keep it that way, any suggestions?
Old 01-04-2010 | 02:35 PM
chambers's Avatar
chambers
Coolant flush and refill would be good, change the rear differential fluid, do a pan drop on the tranny as a flush will probably just disturb some stuff you don't want moving around in there.
