Snowy Shots
Old Jan 7, 2010 | 01:21 AM
  #21
rcman0056's Avatar
rcman0056
Picture:
http://7727773317030044930-a-1802744...attredirects=0
The top picture I think is what you have. The bottom picture is what you want. The top is considered series where if one light goes out they all go out. The bottom is parallel where if one light goes out the other 5 stay on. If the power goes into the + side of each light and you have every - on each light ground to the chassis then you are running a parallel circuit which is what you want. You may also want to try running two relays and hooking 3 lights up to each(try disconnecting 3 lights first to see if it will work). You can also try running the ground wire back up to the battery which will help current flow because the chassis can act like a giant resistor thus slowing down the flow of electrons.
Old Jan 7, 2010 | 01:35 AM
  #22
oefootball_70's Avatar
oefootball_70
I can't look at the pics on my phone, but I am running 3 relays and 3 switches, does that change anything ?
Old Jan 7, 2010 | 08:11 AM
  #23
RubberFrog's Avatar
RubberFrog
check your grounds
check your grounds
check your grounds
Old Jan 7, 2010 | 08:12 AM
  #24
RubberFrog's Avatar
RubberFrog
Did I mention... check your grounds
Old Jan 7, 2010 | 09:07 AM
  #25
BadHab1t's Avatar
BadHab1t
like you said theres snow on it is that what you wanted to hear?:
Old Jan 7, 2010 | 10:06 AM
  #26
nim81's Avatar
nim81
i dont think so.. maybe check your grounds. and then double check your grounds
Old Jan 7, 2010 | 10:45 AM
  #27
EJM05's Avatar
EJM05
Dont forget to check the grounds...
Old Jan 7, 2010 | 10:48 AM
  #28
SMKNRAM's Avatar
SMKNRAM
OE that truck is looking good! I like the lay out of those lights, and would like to see the light bar! And by the way you might wanna check your grounds!
Old Jan 7, 2010 | 10:51 AM
  #29
nim81's Avatar
nim81
maybe add some more grounds. you can never have enough grounds.
Old Jan 7, 2010 | 10:55 AM
  #30
Silvr_Cummins's Avatar
Silvr_Cummins
dude sick snow!! send some to Canada.... we need more!!! sleds dont like dirt haha
