2002 Transmission makes noise
Old Jan 9, 2010 | 03:31 AM
BigAlRam's Avatar
BigAlRam
Smile 2002 Transmission makes noise
Okay, as I stated in my prior posts, I am new to the forum and a new gen 3 owner. I recently purchased my truck from my dad, and the other day when going to the ATM (to pull out gas money LOL), I could here a slight grinding noise when I would shift the trans from park to reverse, and also from park to drive. I did a search and couldn't find anything. Is this normal or do I have problems coming??? Thanks for reading this
Old Jan 9, 2010 | 09:07 AM
ramhunter9's Avatar
ramhunter9
you have problems comming. sounds like your dad saw you comming.
do a search on differential noise and do lots of reading you answere is in their.
Old Jan 9, 2010 | 09:11 AM
stuntpilot's Avatar
stuntpilot
Check your drive shafts before you condemn your transmission!
Old Jan 9, 2010 | 10:56 AM
nim81's Avatar
nim81
how many miles on your truck and is it the 5.9 or 4.7? if its the 5.9L you have the wonderful 46re POS tranny. but do check the driveshafts first. have someone get under the truck and look and listen while you sweep through all the gears
Old Jan 9, 2010 | 11:32 AM
BigAlRam's Avatar
BigAlRam
I guess what I mean by grinding, it almost sounds like when you try and put it into park when the vehicle is still moving, which makes me think it's in the tranny. I am not sure what one they used behind the 4.7 turd.
Old Jan 9, 2010 | 12:30 PM
nim81's Avatar
nim81
i believe either the 45rfe or 545rfe.
Old Jan 10, 2010 | 08:42 AM
BigAlRam's Avatar
BigAlRam
nim, nice truck! How much lift if any do you have?
Old Jan 10, 2010 | 09:16 AM
matthewbeard's Avatar
matthewbeard
my 4.7 has the 45rfe, when you have your foot firmly on the brake and you go from park to drive it a very slight griding noise? mine started doing that just before i left for overseas, only heard when i was at a drive through and started shifted outta park with my window down.
Old Jan 10, 2010 | 09:48 AM
nim81's Avatar
nim81
just a torsion bar level at the moment. soon i will be looking at 35" tires and maybe a 3" body lift. it all depends on how much i am going to be owing uncle sam this year
