Driver door seems to be jammed
Old Jan 11, 2010 | 09:47 AM
espinosafell's Avatar
espinosafell
Default Driver door seems to be jammed
I woke up this morning not being able to open my drive side door. It seems like it is jammed, the door will not unlock with the key or key fob. It seems like it is jammed or stuck inside the door. Any ideas before I tear down my door. The will open if I try opening it from inside but not outside of the door.
Old Jan 11, 2010 | 09:50 AM
matthewbeard's Avatar
matthewbeard
was it below freezing that night? if so could just be frozen seals.
Old Jan 11, 2010 | 10:10 AM
espinosafell
Yes it was. So should I just warm up the truck or something?
Old Jan 11, 2010 | 10:17 AM
SMKNRAM's Avatar
SMKNRAM
Definitely warm the truck and park that side in the sun today before you tear it apart. BUT if it is working from the inside, there may be more to it! My drivers side window was froze Fri and when I hit the button to let window down the mechanism went down pulled right off the bottom of the window! then when it thawed the window would not stay up! I had to take door panel off and put window back together!!
Old Jan 11, 2010 | 10:21 AM
espinosafell
Ok perfect. I will go ahead and do that. Thank you
