efan
Old Jan 12, 2010 | 09:41 AM
Beastro's Avatar
Beastro
Default efan
im at work no time to search this. Will a 96 and up taruse efan fit and what othere cars efans will fit. my junk yard just crushed all there cars
Old Jan 12, 2010 | 09:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
it will fit and some Mark8 and Lincoln Continental fans will work as well. IDK the years on those though
Old Jan 12, 2010 | 10:25 AM
Beastro's Avatar
Beastro
nice thanks
Old Jan 12, 2010 | 01:23 PM
cheapbeater's Avatar
cheapbeater
i thought it had to be from a 3.8 taurus? which is like late 80's to 1995....?
Old Jan 12, 2010 | 01:51 PM
Beastro's Avatar
Beastro
dont know we will see im going to meausre the trucks radiator tonight. tommorow after work going to go measure some efans at the junk yard off of a 96 turus and a couple lincons.
Old Jan 12, 2010 | 02:33 PM
WWJD's Avatar
WWJD
I am confident when I say that any front wheel drive ferd with the 3.8 liter v6 will get it done. Also, Mercury sables are the same cars. Spray some high dialectic grease in to that thing before you install too!
Old Jan 12, 2010 | 02:43 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I thought those 3.8s ran up to 2000
Old Jan 12, 2010 | 07:40 PM
Beastro's Avatar
Beastro
What is high dialectic grease? And where all in the motor part of the fan?
Old Jan 12, 2010 | 08:37 PM
dirtydog's Avatar
dirtydog
Moderate User
90-95? Taurus 3.8L but for sure the 94 & 95 one's. The Mark VII is a little larger.
I have a Brand New 3.8L Taurus fan for sale if you interested? better than dropping a 100kmi+ used one in your ride not to mention no need to deal with junyards! Click my sig.
Old Jan 13, 2010 | 07:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Remember, Google is your friend
Q: Why should I use Dielectric grease, and on what?
A: Dielectric grease is a NON-conducting grease that seals out moisture and
therefore prevents corrosion on electrical connectors. This also happens to
be one of the main problems with older VWs, and currently one of the causes
of bad idle/ecu (connector) failures. The jury is still out on this
grease... some claim it will get hard. Others have suggested to use a
conducting paste as used on aluminum residential wiring. The latter will
aid in conduction, but should not be used in high voltage cables (spark
plugs) or where several wires are adjacent because of potential shorts.
