6.1 Transplant into 04 Ram
Old Jan 12, 2010 | 07:43 PM
darryl h's Avatar
darryl h
Smile 6.1 Transplant into 04 Ram
I have a complete 6.1 hemi from a 2008 SRT8 Jeep to install in my 2004 5.7 shortbox 4x4 Ram. Has anybody done this before, or anybody have advice, tips, or "beware" to help me out???
Old Jan 12, 2010 | 07:46 PM
EJM05's Avatar
EJM05
Im no help but can you put up a pic of the beastly engine...
Old Jan 12, 2010 | 07:59 PM
nathangfnd's Avatar
nathangfnd
just a FYI you might have some issues with the comp sending the wrong amount of fuel to motor and stuff like that.
look on 2nd gen and you will find some people with issues from swapping in 360 motors when the comp is still seeing it as a 318.
Old Jan 12, 2010 | 08:06 PM
oefootball_70's Avatar
oefootball_70
Did you get the entire PCM set up? I know guys over on DT have done it.
Old Jan 12, 2010 | 08:17 PM
MOPAR78's Avatar
MOPAR78
These guy's sell the swap parts and should be able to help.
http://www.arringtonengines.com/
Old Jan 12, 2010 | 08:19 PM
oefootball_70
YOu should build up the motor before you drop it in. New ported ad polished heads, new aggressive cam, new springs and lifters. That would be sweet.
Old Jan 12, 2010 | 11:46 PM
05RamMan's Avatar
05RamMan
It won't work. So Ill tell you what Ill do for you since I like you. Tell me where to pick up that junky ole engine and ill be on my way.
Old Jan 13, 2010 | 01:27 AM
Freakinkeith806's Avatar
Freakinkeith806
Sounds like a good project coming on! I agree on a build up on the engine before hand. Before you decide to do it later, new cams on those sound so sick
Old Jan 13, 2010 | 07:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would also build it up before changing it out. Do what ever you want to it while it is out and on the stand. I also agree you will need the PCM and everything else that goes with it. What trans came with it? Will you need a custom drive shaft?
Old Jan 13, 2010 | 09:25 AM
darryl h's Avatar
darryl h
The engine came with all the electrical out of the SRT8, but no tranny.
It's from a rollover with only has 15000 kms on it. It has the stock headers attached, don't know if they will fit the Ram? If the 6.1 have the same exhaust port configuration as the 5.7? The SRT8 is pretty raunchy right out of the box, so I was planning on trying it out as is.
Was planning on bolting it up to my 545RFE, changing to an aftermarket torque converter, transgo shift kit and changing the clutch packs to beefier kolene set-ups through Moe's.
