advice on 3.92 to 4.56 swap with stock 20 wheels
Old Jan 14, 2010 | 06:01 PM
I DRIVE A HEMI RAM DAMNIT!'s Avatar
Default advice on 3.92 to 4.56 swap with stock 20 wheels
Im runnin stock...20`` wheels and goodyear wrangler HP(gonna get Cooper Zeon LTZ soon tho)...will I tear anything up if I switch to 4.56s with the stock wheel and tires sizes?
Old Jan 14, 2010 | 06:06 PM
HammerZ71's Avatar
HammerZ71
Nope, and you won't even have to recalibrate your speedometer either.
Well, let me amend this. You won't tear anything up IF you find a good shop to do the install AND you break them in properly...
Old Jan 14, 2010 | 06:07 PM
JoeHemi's Avatar
JoeHemi
nope!
Old Jan 14, 2010 | 06:53 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
BUT...........
you will need to trim the carrier pin for the 456s to clear. I went through this and so did anyone else using 456s although thier installer may not have told them.
http://www.motivegear.com/tech_info/...tructions.html
CHRYSLER
PROBLEM: CHRYSLER: 9.25", 12 Bolt Cover, 4.56 and Higher.
I bought 4.56 gears for my 1/2 ton pickup, but I cannot get the cross pin into my carrier.
SOLUTION: It does not matter whose gears you use. You will need to modify your cross pin to use a 4.56 or higher gear in your vehicle. This applies for open differential, Auburn and Eaton differentials. The pin will need to be cut at an angle opposite the bolt hole. Because every manufacturer is different, no measurement is provided.
Old Jan 14, 2010 | 06:54 PM
HemiLonestar's Avatar
HemiLonestar
You will however have a severe drop in gas mileage due to the fact that you won't be able to keep your foot out of it!
Old Jan 14, 2010 | 07:07 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Hell, mine sucked when I first got my truck so Ive never minded but you do have a point, especially if he is keeping stock 20s with 32" tires
Old Jan 14, 2010 | 08:17 PM
02Steve1990's Avatar
02Steve1990
I have to post because the OP's username made me LOL
Old Jan 14, 2010 | 09:12 PM
I dont know the exact tire size of hand..they are just factory stock Wrangler HPs on the stock 20in wheel. I have a weird shake..not hardly noticable...it may be the tires or shocks..they trk has only 30k on it so..I am kinda scared haha! I was gonna have my tranny guy look for a new torque converter,shift kit,and programmer...but he said with 4.56s I probably wouldnt need that...and he had a dodge truck there that he just swapped 3.92s for 4.56s. A tire shop put on two different size tires on the front and he put it in 4wd and tore it up! What kinda money am I lookin at for the swap? He had to call his parts man and see what it all would cost..
Old Jan 15, 2010 | 01:56 AM
06 Ram5.7's Avatar
06 Ram5.7
My gas mileage sucked stock, but when I switched to the 4.56's, my gas mileage stayed pretty much the same. And to answer the original question, like was stated earlier, as long as the gears are installed properly, you should have no problems whatsoever.
Old Jan 15, 2010 | 02:59 AM
JoeHemi's Avatar
JoeHemi
So it still sucks?
