PA 3" BL installed
Old Jan 16, 2010 | 05:49 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Default PA 3" BL installed
Ok not much time so Ill make this quick. As some of you know I did my 3" BL over the weekend. Ive got lots of pics but I will leave these with you for now.
I can tell you I did not remove my power steering lines, trans lines from the block, drivers side battery cable from frame (ground), fuel filler from body or ground from cab to bed.
You really do not need to take loose the e-brake cable if you adjust slack in the cable itself.
Also, ***** a die grinder and cutting, grinding discs. A Sawzall with a metal blade did it all in about 10 mins for the front bumper brackets and from frame rails.
Here is a before and after. I have not put on my gap guards yet because I likely will just get full rear liners
Here is a link to all the pics for now.
http://cid-fb87bd8396fbfbf4.skydrive...ch%20total%5E6
Here are some before and after.
Old Jan 16, 2010 | 05:56 PM
RubberFrog's Avatar
RubberFrog
Looks good. What's with the anti-grinder hate? lol
Old Jan 16, 2010 | 06:10 PM
HammerZ71's Avatar
HammerZ71
What are you going to do about the grill guard, winch mount? Because that's the stumbling block keeping me from going any higher...
Old Jan 16, 2010 | 06:12 PM
sharkhunter10's Avatar
sharkhunter10
Looks good! and do those spark plugs really work to make a flame out the exhaust tip. Ive heard to do that but never really thought much of it
Old Jan 16, 2010 | 06:23 PM
JoeHemi's Avatar
JoeHemi
gunna do bigger tires now? Those kinda look dinky compared to before the lift.
Old Jan 16, 2010 | 06:50 PM
EJM05's Avatar
EJM05
Looks good. I think you need 26" rims now. haha. jk.
Old Jan 16, 2010 | 07:45 PM
fk1022's Avatar
fk1022
looks great
Old Jan 16, 2010 | 07:58 PM
irelandshemi's Avatar
irelandshemi
veeery nice looking truck weed, how long did it end up taking ya
Old Jan 16, 2010 | 08:00 PM
Shiloh 24's Avatar
Shiloh 24
It's more than just a spark plug. You have to have a coil powering the plug and there is some kind of kit I believe that cycles the raw fuel through the motor so the fumes ignite in the ignition. It doesn't work if you have cats it will burn them to hell and back.
Old Jan 16, 2010 | 08:26 PM
RubberFrog's Avatar
RubberFrog
The tires look like they can actually function offroad now! Why does everybody always want a stuffed tire with no articulation?
